Weird problem
28 Feb 2007
Leeds/Sunderland
This problem has benn hapening for a long time now but i want it gone.
when i log off or shutdown windows it says this.
"The drive is not ready for use; its door may be open. Please check drive A: make sure that a disk is inserted and the drive door is closed."
Its really annoying because i dont have a drive A
:confused: :confused: :confused: :confused:
In your bios - you should be able to set drive A to not installed. Once that's set windows will no longer attempt to find a drive A.
No drive A:...So im presuming you dont have a floppy installed?
If you dont, just disable the floppy in the bios.
It will be the floppy disk controller or something along those lines.
