Weird problems in game (6800nu 128mb)
6 Nov 2004
Hi i get this weird when running games and 3dmark's.
When I play games or run 3dmark06 it runs well then suddenly it might go into an area of high detail - then my computer will just completly slowdown and do less than 1 fps.
An example of this can be in games like BF2/F.E.A.R/HL2 - when I run at high settings i do actually get decent fps on my Leadtek 6800nu but suddenly if I look somewhere that has detail it will completly slowdown to less than 1FPS - so I have to look at the floor to get the normal FPS back.
People with my card are getting around 2K in 3dmark 06 - I feel i can get this score also - when i start it battle of proxcon gets around 20-7 fps then from out of nowhere it drops to 0fps, same with the firely tests and the others.
What can be causing this problem? im running 700mb ram - is it purely due to that?
used to happen to me in battlefield 2, had to put texture detail to medium since 128mb is not enough for it. also more system ram stopped the constant stuttering.
Ye I can understand why it happens in some games, but 3dmark06? I've seen people with similar specs score 2000 odd and im scoring 800 - well I've got 512mb arriving soon to add to this 512 - and will sell the 256 hope it helps.
Not sure but i also have a 6800 and have the problem in Battlefield 2, when you look towards built up areas (or anywhere in Karkand) it slows down till you look at the floor. I have everything on medium also and it seems to happen at random - however i reinstalled my graphic card drivers and it seems to be fine since then.
id like to know how to stop it permanantly myself as reinstalling everytime it happens gets annoying! although i've not had it happen in HL2 though but it might be worth reinstalling drivers?
Well my monitor resolution is 1680X1050 - but even games when I run at low resoltions this can happen, it's an annoying problem because I know my card can generate the frames its trying to show - but its like soemthings blocking it almost.
