Caporegime
Hi all
I've got this weird fancy column radiator in the kitchen and want to fit a trv to it, however I cannot figure out the connections to the rad as I've never seen this type before.
There appears to be a 15mm inlet for the pipe at the bottom, converting to 22mm outlet? But I can't see how the tail connects to the bottom of the radiator, as there's no visible way to screw it in, only the nut at the top that squeezes down onto the valve.
Has anyone seen this and can advise what parts I need please? Thank you.
