- 18 Oct 2002
Hi All,
I've replaced the tubing in my build but noticed that the fittings on the radiator leak if I open the port directly above it (I was doing this to try and get the air out).
The fitting which leaks is the one directly below the port I open.
I've added some photos below so you can see what I mean. Anyone came across this before? It's perfectly fine otherwise and has been leak testing for 24 hours without issue. Is there some weird physics explanation for this?
https://photos.app.goo.gl/qfVBMq1ir8iVAHQi8
