Weird ram problem
1 Jul 2009
Edinburgh
Hi all, I'll try and make this quick.
A year ago I built an AMD system, with 2 sticks of Hyper X 1600mhz (4GB total). A few months later one stick failed - rma'd it and installed it again. Low and behold another stick failed! I put up with 2gb for ages then bought another 4gb set and you've guessed it - one stick has just failed. What's going on? I've set it to 1.65v, 1600mhz, 9,9,9,27. Could the slots be faulty? Should I try the other coloured slots?
Your help is much appreciated :)
Full specs:
Item: Antec 300 Three Hundred Case - Qty: 1
Item: Gigabyte GTX 460 OC 1GB GDDR5 OC Edition Dual DVI HDMI PCI-E Graphics Card - Qty: 1
Item: Kingston 4GB (2x2GB) DDR3 1600MHz HyperX Memory Kit CL9(9-9-9-27) 1.7 - 1.9V - Qty: 1
Item: Asus M4A87TD/USB3 870 Socket AM3 8 Channel Audio ATX Motherboard - Qty: 1
Item: Sony AD7241S 24x DVD±RW DL & RAM with LightScribe SATA Optical Drive - OEM Black - Qty: 1
Item: OCZ Stealth Xstream II 600W PSU - 3x SATA 2x PCI-E - Qty: 1
Item: AMD Phenom II X4 955 Black Edition Socket AM3 3.2 GHz 8MB L3 Cache Retail Boxed Processor - Qty: 1
Item: Xilence Red Wing 120mm Quiet Fan - 3&4pin connection - Qty: 1
Item: Western Digital WD5000AAKS 500GB SATAII 7200RPM 16MB Cache - OEM Caviar Blue - Qty: 1
