Weird refresh rate thing....
THT
THT
10 Mar 2004
I have an issue with monitor refresh rates on XP.
History:
Previously I had 2 17inch monitors on this X550 video card - a samtron on output 1 and a benq on output 2.
Both ran at 1024x768 @ 85Hz
Now, as i got a new 19nch, i put that on output 1 and moved the samtron to output 2.
The 19incher now runs at 1280x1024 @ 85Hz but the Samtron will only do 60Hz
I know that the card can output @ 85 and the monitor can support 85 - so why does it only do 60!
Although windows says its doing 85, the monitor itself says 60 and you can see its flicking
Any ideas?
have u tried running ure new 19inch at 1024 and seeing if it then lets u run that and the samy at the same 85hz? i know its not what u want but just as a test.
