Hi All,
Well im currently on T+ 1 day and counting with my dual LCD setup
Here if you want a looksee
However ive started to notice a slight issue with it, when the monitors go onto standby and are then 'woken' up again my secondary will come on as per normal and display the screen, however this is quite dark and gloomy. The only way to restore normal brightness (that ive found so far) is to open up ATI Catalyst control panel. As soon as this is opened the screen will blink and normal service will resume.
Hopefully this is easlily fixed?
Any help advice appreciated.
Regards,
Dave.
P.S Not too sure it'll make any diff but using UltraMon. Primary display on DVI and secondary using DVI convertor.
Regards,
Dave.
