weird stuttering//graphical glitches in games?
12 Apr 2013
hello. ive been noticing recently that all of the games i play on my pc have this odd stuttering, but when i read the FPS i get at least 60. i was wondering what could cause this, and should i change some of the settings with my system in the catalyst control, or whether that would effect anything. ive also noticed some odd issues like shadows being glitched, for example in gta 4 in the far far distance, buildings flash black, like a cover of shadow. a similar issue with the mountains in skyrim aswell. ive never had a BSOD, or a system crash but i have had the odd game crash now and then. i was wondering if there was anything i could do to fix my issues, as they are starting to get on my nerves. thanks a lot!
my build:
Ram: 1333MHz RAM Speed, CAS 9-9-9-24 Timings, 1.5v VDIMM, Lifetime Warranty with Corsair.
Processor: Intel Core i5-3570K 3.40GHz (Ivy Bridge) Socket LGA1155 Processor £155
Motherboard: MSI Z77A-G43 Intel Z77 Socket 1155 DDR3 PCI-Express Motherboard £80
Graphics Card: MSI HD 7870 Black Knight OC 2048MB GDDR5 PCI-Express Graphics Card [R7870-2GD5T/OC] £180
HDD: 500GB Seagate Barracuda ST500DM002 3.5" SATA III Hard Drive £40
Case: Cooler Master Elite 430 Black Midi Tower Window Gaming Case £40
PSU:600W Corsair Builder Series 600CX 80PLUS Bronze Power Supply £50
DVD burner: Samsung SH-118AB/BEBE Black 18x SATA DVD ROM - OEM £10
OS: windows 7 home premium
how much ram are you running? id want to go for some 1600mhz
if 4gb and 32bit windows it will stutter slightly in certain games
id try with 1600mhz first,thats all I can think of that's causing the stuttering
gta 4 isn't verywell coded either,it does stutter from time to time
a mild overclock on the cpu would help you too,no point in trying to oc your existing ram,they wont oc well
it could be drivers,or down to 1333mhz pc memory or running stock cpu/gpu clocks idk
you can overclock your gpu aswell in ccc/overdrive,move the sliders for the core and memory a little?
im only guessing at pc memory but imo 1333mhz is a bit limiting,and yeah that memory would be ok
yeah i was looking to replace my RAM anyway, as im pretty sure one of the sticks is defective, it failed a lot of tests on memtest so, im sure thats causing my issues.
