I am currently experiencing a problem whereby a Linux box cannot ping a server which a Windows XP box, plugged into the exact same cable/port etc, can ping.
Here is how our network is configured -
The ISA Server has 3 NICs, one connected to the internal domain, one for the DMZ and one external interface.
We have an exchange server internally, with an Exchange bridgehead in the DMZ (to allow the complex routing/header re-writes that we require).
As we cannot plug the external connection in until the system has received security accreditation, I am hoping to use the Linux box (plugged into the external interface of the firewall) as an external SMTP server (using sendmail) to test our Exchange routing.
Here's the problem:
- I can ping the Linux laptop from the Exchange bridgehead.
- I cannot ping the Exchange bridgehead from the Linux laptop.
- If I replace the Linux laptop with an XP laptop (using the same IP and network settings), I can ping the Exchange bridgehead from the laptop (which, in my mind, rules out the network itself and the firewall as an issue).
The domain is Server 2003. The Linux box is running Suse and has Webmin and sendmail installed.
We have opened up the Firewall completely, but this made no difference.
I am a bit of a n00b when it comes to Linux, so any help/advice welcomed
Thanks in advance
Richard
Here's the problem:
Thanks in advance
Richard
