weird temp monitor
6 Dec 2006
okay ive got three temperture moniors on my pc. speedfan/pcwizard2007 and everest(trial) and they all have differnt readings for example for the cpu speedfan says that the four cores are around 25c to 30 c idle
And then everest(trial) says the cores are at 40 c to 46 c and its idle
pc wizards says mobo at 255c and cpu at 198 c which is a joke
so which is a more accurte programe ?
speedfan or everest ?????
thx
Ace Modder said:
has you checked out which temps your reading from with speedfan
yes they seems to be fairly lower than everest and pc wizard dunno why about 10 c lower .
my case temp under load gets to about 53 c is this a problem ?
Also how do i speed up the system fans i mean how do you adjust the voltage ?
my cpu is watercooled and idle apprently to speedfan at 23c -28 c perc core and then with everest their about 40- 45 on each core and i am just idle so whats with this ??
thx
