Weird USB disconnect/reconnect sound...
18 Dec 2010
I have this problem where I can hear the USB device disconnect/reconnect sound played randomly. When I'm playing games it causes the games to lag at times when the sound is played which is really frustrating.
Is there any way to pin point which USB device is causing this maybe with a program?
Thanks
Event Viewer, Windows Logs, System (sort by date/time) should be at the top when you hear the disconnect sound.
Glad you got this sorted, had a similar problem a few months back, I ended up just disconnecting everything from my pc and trying everything in individually until I found the culprit, cant remember what it was though but do know I got it sorted
Thanks. If i didn't find that software, that method would have been my last resort.
