Weird vpn lan - lan issue
30 Jul 2003
Afternoon, im having a weird issue that ive not seen before and wondered it anyone had some ideas.
All sites have draytek 2820 Routers
Site A - Spain
Site B - UK
Site C - my house :) 2 miles away from site b
so until last night, the vpn was working as normal.
This morning, the vpn tunnel dropped. i checked all setting on both sites, nothing has been changed.
Site A router wont dial B just blanc refuses.
Tried L2TP (what it normally uses) and PPTP, neither work
Ipsec creates a tunnel but wont flow traffic nothing on tx or rx logs ....
So i tested site A - C .... Works fine (A always dials out into B)
then tested C - B using the same settings for both tests. Works fine....
so both routers are functioning perfectly ... so why dont they want to talk :|
Site A is on Globatel site B is on Nildram
Im so confused as to why they work by proxy but dont wanna by themselves :s
Weirder still the individual pc's at site A will dial up via L2TP into the site B router no problems.
What on earth is going on HELPPSSSS PLIXXXXX
