** WELCOME MAGICOOL TO OCUK **
rjk
rjk
OcUK Staff
8 Aug 2007
Hi Guys
I am delighted to introduce the MagiCool brand to you guys.
MagiCool offer a full range of copper radiators in a huge variety of sizes and cooling capacities.
Every MagiCool rad has low resistance and is a fantastic price/performance product at every size and price point.
MagiCool Copper Radiator - 140 mm @ £23.99 inc VAT
The copper fins are specially designed for silent fans, while the parallel coolant channels reduce liquid resistance to a minimum. On both sides of the radiator M3 threads are integrated to allow flexible fan mounting, on top chamber both G1/4" threads allow easy installation of all common fittings and barbs.
Specifications:-
- Dimensions: 183 x 29 x 142 mm (WxHxD)
- Material: copper (fins), brass (atria)
- Color: Black
- Compatibility: 1x 140mm fan
- Connectors: 2x G1 / 4
Only £23.99 inc VAT.
ORDER NOW
MagiCool Copper Radiator - 280 mm @ £31.99 inc VAT
Specifications:-
- Dimensions: 323 x 29 x 142 mm (WxHxD)
- Color: Black
- Compatibility: 2x 140 mm fan
Only £31.99 inc VAT.
ORDER NOW
Magicool Copper Radiator - 360mm @ £67.99 inc VAT
Specifications:-
- Dimensions: 400 x 35 x 180 mm (W x H x D)
- Color: Black
- ~~Compatibility: 2x 180 mm fan
Only £67.99 inc VAT.
ORDER NOW
MagiCool Copper Radiator - 420 mm @ £47.99 inc VAT
Specifications:-
- Dimensions: 463 x 29 x 142 mm (BxHxT)
- Color: Black
- Compatibility: 3x 140mm fan
Only £47.99 inc VAT.
ORDER NOW
Magicool Copper Radiator - 540mm @ £79.99 inc VAT
Specifications:-
- Dimensions: 580 x 35 x 180 mm (W x H x D)
- Color: Black
- Compatibility: 3x 180mm fan
Only £79.99 inc VAT.
ORDER NOW
MagiCool Copper Radiator I - 120 mm @ £19.99 inc VAT
As a professional OEM manufacturer in Computer liquid cooling area, Magicool´s product line covers full range of liquid cooling components, including different size of heat exchangers, water tanks, pumps, cooling blocks and accessories. Excellent price-performance ratio and reliable quality make Magicool products unique.
With its compact design and excellent cooling performance, the Magicool radiators become top choice of water cooling users. The copper fins are specially designed for silent fans, while the parallel coolant channels reduce liquid resistance to a minimum. On both sides of the radiator M3 threads are integrated to allow flexible fan mounting, on top chamber both G1/4" threads allow easy installation of all common fittings and barbs.
Specifications:-
- Material: Copper fins
- Brass chambers
- Dimensions (LxWxH): 150 x 120 x 30mm
- Connectors: G1 / 4 (Standard)
- G3 / 8 1/2 (optional)
- Weight: about 350g
Only £19.99 inc VAT.
ORDER NOW
MagiCool Copper Radiator II - 240 mm @ £28.99 inc VAT
Specifications:-
- Brass chambers
- Dimensions (LxWxH): 276 x 120 x 30 mm
- Thread: 2x 1/4
- Weight: 650 g
Only £28.99 inc VAT.
ORDER NOW
MagiCool Copper Radiator III - 360 mm @ £32.99 inc VAT
Specifications:-
- Dimensions: 394 x 30 x 124 mm (W x H x D)
- Dimensions: Weight: 900 g
- Color: Black
- Compatibility: 3x 120mm fans
Only £32.99 inc VAT.
ORDER NOW
MagiCool Copper Radiator I PRO - 120 mm @ £23.99 inc VAT
Specifications:-
- Brass chambers
- Dimensions (LxWxH): 157 x 120 x 46mm
- Weight: about 650g
ORDER NOW
MagiCool Copper Radiator II PRO - 240 mm @ £32.99 inc VAT
Specifications:-
- Brass chambers
- Dimensions (LxWxH): 315 x 120 x 30 mm
- Weight: 999g
ORDER NOW
MagiCool Copper Radiator III PRO - 360 mm @ £39.95 inc VAT
Specifications:-
- Brass chambers
- Dimensions (LxWxH): 415 x 120 x 46 mm
- Weight: 1.5 kg
Only £39.95 inc VAT.
ORDER NOW
MagiCool Copper Radiator X90 - 92 mm @ £19.99 inc VAT
Specifications:-
- Brass chambers
- Dimensions (LxWxH): 133 x 94 x 43mm
- Weight: about 450g
ORDER NOW
Magicool Copper Radiator 720 Hexa Xtreme @ £84.95 inc VAT
Proven quality and a perfect price-/ performance ratio is what makes this Magicool radiator great! The Magicool Hexa radiator offers not only excellent looks and great quality of manufacturing, the cooling performance is also truly exceptional. The copper fins are specially designed for super-silent fans (with low air flow). For a very low flow resistance the coolant channels are installed parallely.
The radiator has 2 G1/4" threads integrated, allowing installation of all common fittings
Specifications:-
- Dimensions: 395 x 45 x 240 mm (WxHxD)
- Color: Black
- Compatibility: 6x 120mm fan
Only £84.95 inc VAT.
ORDER NOW
MagiCool Copper Radiator Double Power - 80 mm @ £20.99 inc VAT
Specifications:-
- Brass chambers
- Dimensions (LxWxH): 90 x 190 x 46mm
- Weight: about 900g
Only £20.99 inc VAT.
ORDER NOW
MagiCool Deep Quiet 700 - DC12V Pumpe @ £39.95 inc VAT
Specifications:-
- Dimensions: 100 x 80 x 117mm (LxTxB)
- Weight: 650g
- Connection: 2x G1 / 4
- Inlet: 1x G1 / 4
- Pumping capacity: 700 l / h
- Lifting height: 1.7 m
- Input voltage: DC 12V
- Power: 10 Watts
- Life span: 50,000 hours
ORDER NOW
not too dissimilar. the finish of the EK imho is a little better.
the performance is pretty good and comparable to EKWB PE range.
these are not intended to win awards for ultimate performance as the pricing suggests.
but they are a good quality product that I can back based on build quality and price performance.
If you want something a little more refined, the EKWB products are maybe a better choice for you. If you are looking for ultimate performance, the XSPC RXv3 rads are the top of my list currently :)
These look really well priced ! Im looking for a 240/360 to go in the front of my case where it will never be seen again. Just looking to increase loop capacity really and knock an extra degree off. Whats the flow restriction like compared to say XSPC rads ?
Im also guessing the Dimentions are wrong on the "MagiCool Copper Radiator II PRO - 240 mm @ £32.99 inc VAT"
it claims 30mm thick yet its the pro so should be 46mm thick ? as this only makes it as thick as the standard one ?
The standard ones look a little anorexic. Good price points though, should hopefully get more people to dip their toes in water cooling.
Got to ask though, what is going on with that pump lol. It looks like a fish tank bubble machine.
Seriously ? This is my least favorite out the lot, Its a good price but as some one said looks like it belongs in a goldfish bowl. The rads i might give a go but not the pump
The was a time when all pumps used to watercool PC's were repurposed aquarium/pond pumps (hell even today the are only about two that aren't). Submerged pumps are good (especially for small loops) because not only do you get the pump/res in one but the res/coolant acts as noise dampening for the pump.
Hi Guys
Excellent price for a 46mm 360 rad.
I see they are on pre-order, any idea when they are due in, so we know when the price will probably go up ?
