- 3 Jul 2005
Should I keep them on, as I am overclocking and im not sure if keeping them on would increase my heat or not
thanks
thanks
monkeypants said:Yeah it'll be fine so long as you clean out the dust every so often. Personally I'd leave the case one in as that won't affect overclocking performance as much as removing the graphics card filter.
DaZzZa said:just remove them they make your fans more noisy
salami1212 said:how?
Jokester said:He's correct, a grill restricts air flow (= noise) through a fan.
I chopped the grill off the front of my Antec SLK3700BQE and the noise from the front fan dropped significantly.
Jokester
badbob said:Of course I'm talking about the metal meshing of the case, not any removable foam/plastic dust mesh.
Here. The metal that's the case, with the holes. Mark out the area directly in front of the fan blade circumference and cut away so the airflow is not obstructed. It'll depend on your case of course, if the foam/plastic mesh in front will plop out and fall into the blades don't do it. But if there's nothing there nor any cables you can do this.salami1212 said:what do you mean??
