people will probably need to know your case , just in case size becomes a limiting factor.
No chance of an AIO?
@montymint
so the Arctic FREEZER 240mm would be OK then?? I won't be overclocking the CPU or any high usage productivity on it..
game max f15G tower
I use an Arctic Freezer II 240 with a 5900X, temps don’t get over 72 degrees even on sustained heavy all core workloads. Idle is between 35 and 40 degrees.@montymint
Go for the Arctic Freezer 2 280 if you can but check it will fit. Gives you a bit more cooling power.
Aio 360mm front , 240mm top for that case.I was looking at a game max f15G tower.
Plus you wouldnt want to loose the 2x 200mm Rgb Fans at the front, that's half the price of the case .Thats why I said check if it will fit.
Also why I chose a case that accepts 140mm fans recently.
Please tell which case.Ended up going for a different case. Got good reviews on the most part..
Looks a nice case just read the review mite be worth checking out if you plan a 280mm aio in the top . Just remember the arctic radiator is 38mm, much thicker than most which are usually 27mm or 30mm.went for a DeepCool CK560 in black. Can’t wait to see it in person!
DeepCool CK560 Case Review
The DeepCool CK560 may look like a simple design variant of the CG560, but improves on most of the shortcomings of its sibling while retaining the unique design elements, functional build, and cable management approach, and it even adds tangible extras, like USB-C I/O and the metal GPU support...www.techpowerup.com
