http://www.eventtravel.com/cms/display_seatingplan.aspx?seatingplan_objid=119
Is this what you've already seen? I think the seat numbers rise from pitch side back upwards.
Question, does it matter?
Are you planning not going if you find out the seat you have doesn't look very good on a plan?
WOW Your playing at wembley stadium. I'm sure a steward will direct you to the stage.
