We're going to need a bigger case.
11 Jan 2007
*̡̡ı ̡̡͡|̲̲̲͡͡͡ ̲▫̲͡ ̲̲̲͡͡π̲̲͡͡ ̲̲͡▫̲̲͡͡ ̲|̡̡
Just upgraded my GPU and it only just fits in my case. I cant use a GPU support bracket as this cannot fit as well. I'm looking to get a case which gives enough room for the XFX 7900GTX but I also need to have a minimum of 4 3.5 inch drive bays and a couple of SSD bays. Room for a radiator for GPU cooling as well. All cases I like the look of only seem to support 2 3.5 inch drives and 2 2.5 inch ones. Anyone got any ideas on this? I've googled and only found the above. It will need some RGB niceness. I quite like the look of this one:
Or this:
Maybe the answer is another NAS drive but they are pricey and I already need a new case.
Fractal Design do a number of cases that would do the trick. That's where I'd start looking.
Or a NAS. Move storage out of your PC altogether.
I have chosen the C8 now as I like the look and will probably get the black variant. I am concerned about my drives though. I managed to squeeze 4 3.5 inch drives into my H500i and was hoping I can do so somewhere on the back. I know it has two 3.5 inch enclosures but was thinking if I remove the 2.5 inch bay from the bottom, I could stack a couple of 3.5 inch drives there. Getting another NAS right now is out of the question. Does anyone have this case and could check if this is possible?
Thanks!
Looks nice but a bit outside of Father Christmas's budget. Also seems you need to buy extra stuff to fit the extra HDDs. I can hopefully squeeze them in the C8 somewhere or get a NAS later. I have a spare HP machine I could use as a NAS.
