thanks for all the points lads. I wish we could give rep or karma on this forum.
very interested in the ST65F-G cause 140mm is gonna make things very easy.
just get this psu instead - http://www.silverstonetek.com/product.php?pid=350
650w 80+ gold. only 140mm depth.
fits like a charm in the prodigy.
(yes i have one already)
ocuk dont stock em. but a quick google should show you which etailer does.
Makes we wish I'd found this forum first. I'm running a 1000w modular and think it's way too much.
By looking at your spec a 550w would do and you would still have some power left.
Yeah. I know that now. I've had power issues in the past as my old case had more than what i've got spec'd now. Then I changed cases and most of the crap I had (calthods, lights, additional HDD'ds) were removed.
I was running 5 HDD's at the time, now down to 2. A 60gb SSD & 1tb Samsung. Will have a 120gb soon, but yes, it's now a little overkill.
If you are worried about 550w than go for 650w,
1000w its a bit too much, IMO I would sell it and get something different.
Best place to sell it???
Online auction site?
A solid 550 / 650W. That should cover your needs.Also, what would be a suitable replacement?
