What 7800GTX?
18 Oct 2005
Evening all.
Ive decided on a 7800GTX that im after but im stuck on what make to get.
Ive narrowed it down to the XFX or Asus..
What one? The Asus is the cheaper by £20 but whats the better card?
The clock speed is all over the place on the websites so the XFX says its 475 and the Asus says its 430 :confused:
Will i notice much difference? Ill be maxing it out on BF2 :D
Who gives the Better warrenty and will be arround the longest as i hope to SLI them one day!
Thanks
Mat :)
Ill be playing at max really. To get me the best lag free i can get.
I want to SLI in a couple of years and the chances of finding another OCUK one would be a bit of a pain
i sold mt 7800gtx oc and went to a x1800xt 512, i couldnt run on my monitor past 1680x1050 @ 2aa 4af in bf2 without noticing big slowdown. on my x1800xt (PE) i can run the same res @ 4aa 16af maxed with no slowdown whatsoever.
No need to worry as the latest drivers allow for mis-matching cards to be paired up i.e. a Leadtek BIOS GTX with a Point of View GTX so just get whichever suits your price ;).
Personally I'd just get an X1800XT 256MB card which beats the GTX quite soundly or the X1800XT 512MB which can be had for the same price and wipes the floor with the 256MB GTX.
Mat-mk3 said:
Evening all.
Thanks
Mat :)
Hi there
Don't get either!!
Asus = Terrible warranty & after support!
XFX = Very good warranty and after support!
BFG = The best, lifetime warranty!!
Leadtek = Good 2yr warranty!
If you really want a 7800 GTX go for this from OcUK:-
Leadtek GeForce 7800 GTX Extreme Edition 256MB GDDR3 VIVO TV-Out/Dual DVI (PCI-Express) - Retail (GX-070-LT)
The NVIDIA Geforce 7800 GPUs supercharge gaming - delivering unparalleled performance and advanced visual effects for next generation games. Featuring a revolutionary superscalar architecture and backed by the NVIDIA Forceware software the Geforce 7800 GPUs deliver ultra-realistic effects, unmatched features, and rock solid stability so you can play your game the way it's meant to be played. Currently the quickest card in the world due to the high clock and superb cooling solution. If you want the best then you need this card, which is capable of scoring 9000+ 3D Mark 05 points in the OcUK FX57 Ultima System and even more when overclocked as early reports show users hitting as high as 540MHz core speed and upto 1400MHz memory speed due to the awsome cooling solution on this card which is also silent. Please note OcUK/Leadtek only guarentee clock speeds of 490MHz/1250MHz overclocking past this is not guaranteed but the cooling solution and Leadteks hand picked cores give good overclocking sucess.
- Core clock 490MHz+
- 24 Pixel Pipelines
- 1250MHz+ GDDR3 Ultra Fast Memory
- 256-Bit Memory interface
- 8 Vertex Shaders
- Memory Bandwidth - 41.6GB/sec
- Fill Rate - 11.76 billion pixels/sec
- Games Bundle: Splinter Cell:Chaos Theory & Prince of Persia:Warrior Within
- 2yr Manufacturer Warranty
- Note - For technical support issues you can contact Leadtek by phone on +31 204 109 109 or email [email protected]
****IN STOCK*****
Price: £289.95 (£340.69 Including VAT at 17.5%)
That is the quickest 256MB 7800 GTX available and it comes with a silent cooling solution too and OcUK is the cheapest in the UK for this particular card. :)
Also check out the OcUK branded 7800 GTX, it only runs at stock speeds, same as the Asus your looking at but its only £239.95 +VAT (£281.95 Inc. VAT).
Or alternatively get an ATI X1800 XT 256MB which is quicker than all the 7800 GTX cards and is also cheaper as OcUK have the cheapest price going at just £199 +VAT (£235 Inc. VAT)
Happy shopping!
P.S. When it comes to SLi I am afraid you will not be able to buy a 7800 GT or GTX within the next 3 months, as they won't be around any more from any manufacturer.
can anyone guess who works at overclockers here? i will give you a clue his name begins with G
lol nice sales pitch :D
Gibbo said:
Hi there
Don't get either!!
- 8 Vertex Shaders
****IN STOCK*****
Happy shopping!
yeah your good at selling stuff i presume gibbo, lol :D
HI there
OcUK have just obtained another new card which uses the same cooler as the Leadtek Extreme and is clocked at 460MHz and 1200MHz memory. However the special part is that we only want £234.95 +VAT for this.
It will be on the site shortly and the code GX-033-DE!! :)
Gibbo said:
HI there
Gibbo, that the same one that has the heatpipe cooler as sold elsewhere?
Hi there
Right the OcUK card is £224.95 +VAT which makes us the cheapest in the UK and it has the fancy heatpipe cooling and slightly higher clock speed over a normal GTX. ABSOLUTE BARGAIN!! :D
Gibbo said:
Hi there
Damn right it's a bargain.
Especially if you bring the fact youve not got to change the cooler with something quieter.
:eek:
Done it again mate :p
Gibbo said:
Hi there
Gibbo, from a performance perspective, which card, this or the ATi X1800XT 256MB. The ATi is cheaper too. Also, is that the heatpipe cooler found on the 512MB flavours of the GTX?
