Right, today I ordered an X2 3800+ 939 (around 12 noon). Now first off I want to cancel this, as I've made a stupid mistake purchasing it. I've decided it will be more worthwhile to go Conroe.
I just have a few questions
1) I have had no dispatch email at all, does that mean there having stock problems and havnt dispatched it, and can I cancel the order first thing tomorrow morning?
2) I want a conroe I can Overclock on air. I'm thinking the 6600.
3) What motherboard is the best on the 775 range for overclocking.
4) Will I notice a performance difference between
G.Skill 2GB DDR2 NR PC2-6400 (2x1GB) CAS5 Dual Channel Kit (F2-6400PHU2-2GBNR) (MY-014-GS)
G.Skill 2GB DDR2 HZ PC2-6400 (2x1GB) CAS4 Dual Channel Kit (F2-6400PHU2-2GBHZ) (MY-013-GS)
or could I Overclock the difference?
5) Also! Will my Zalman 9500 fit it!
Basically, I want a Conroe 6600, A good Ocing motherboard, and some G Skill ram ^_^
Cheers
Milz
Cheers
Milz
You always knew I was right
Gigabyte boards for the win
Also I will get DDR2 800 one of the G Skill kits ^_^
