- 24 Feb 2009
- Teesside
So like the title says, what is it that kills or damages the CPU? Is it just heat or are there other things to take into account? Do increased voltages cause direct damage (not just increased heat which may later cause damage).
Just wondering as my VCore is already at 1.52V but cant get over 3.2Ghz, though I know I should be able to get to 3.5Ghz easily. My temps are around 19C - 22C idle and never get over 46C when running prime95. Now I know CPU's can be run a lot hotter than that, but Im just wondering if increasing my VCore more(already raised 0.2V) will cause other damage besides the extra heat?
Thanks
Thanks
still alive through but just don't like going past 333FSB
