What additional components
7 Jun 2005
Hi,
I've just ordered:
Asus P5K-E WiFi Intel P35 (Socket 775) PCI-Express DDR2 Motherboard
Intel Core 2 Quad Pro Q6600 2.4Ghz
From my previous computer I have-
Akasa Paxpower 400W Ultra Quiet PSU Black v.3 - ATX 2.0
BFG 8800 GTS OC 320MB DDR3 DVI PCI-E Graphics Card
Creative Sound Blaster Audigy SE 7.1 OEM PCI Soundcard
Thermaltake Soprano Silver Middle Tower Case
Zalman CNPS7500-ALCU CPU Cooler (Socket 478/754/939/940/AM2/LGA775)
Seagate ST3250823AS 250GB 7200RPM SATA/150 8MB Cache - OEM
Here are my questions
Which of those previous parts will bottleneck the new system if i didn't replace them? If its too weak, what do you recommend?
I need memory also, I don't know yet 2gb or 4gb, value or high performance. What are the views there?
It's mainly a gaming computer. I'd like to overclock, to some kind of "safe" middle ground, 3.4ghz or something?
Budget for memory depends what else needs replacing, I have no firm limit, but i didn't plan to spend all that much more.
Thanks for the help
(edit) Oh one final thing, i am ok with running either 32bit or 64bit Vista - whatever will be best for me
I would personally upgrade the psu as 400watt on a quad core and an 8800gts overclocked is pushing it perhaps consider the Cosair 520W.
Your other components should be ok, you could consider a better heatsink if trying to get 3.4ghz.
With vista and games i would recommend getting 4gb ram now as its so cheap anyway at the moment.
I've used both 32bit and 64bit Vista and I would say either will be ok just check to make sure there are 64bit version drivers out for all your hardware and peripherals before going 64bit.
How much power output should I be looking at? I'd like to look around the PSU's, so having a rough idea of the drain of that gfx, cpu, 1hdd, 2dvd etc will help me know what i can discount
With regards to RAM, what brand/speeds should I be looking at?
Also how necessary is better cooling? Is my Zalman adaquate at stock only, good for only low level OCing, or somewhere midground?
I didn't OC the 8800 yet, any considerations there with fans and cooling if I chose to?
Thanks
