- 18 Dec 2006
Hi folks!
I have an avi file on my computer that I wish to convert to dvd format, burn to dvd to watch in a normal dvd player.
After searching these forums I found a thread in which lots of people recommended the ConvertXtoDVD software.
Using this software, I appear to be successfully converting the file and burning the disc (its def burned something when checking the underside of the disc) but when I put the disc in my player or even my pc it would appear that nothing is on it.
Anyone familiar with this software? Any ideas where I am going wrong? I am pretty sure the session is closed on the disc. If its any help, here is the log from the program, which doesn't show any problems.
30/01/2007 17:27:38 info ********** Report session closed ***********
30/01/2007 17:27:04 info Media removed. Burning layer not ready to write
30/01/2007 17:26:55 info Folder F:\Documents and Settings\xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx\ has been removed
30/01/2007 17:26:55 info Finalization Time 00:00:05 - Total completion time 00:04:59
30/01/2007 17:26:49 info Write finished in 00:04:53 - Finalization start here. Avg. burn rate 5.56
30/01/2007 17:22:31 info Lead-in burning time (mS) 35358
30/01/2007 17:21:55 info Write started 1003856 sectors to write
30/01/2007 17:21:55 info Writing speed requested x6.0, effective x6.0
30/01/2007 17:21:55 info Available write speed: 6x
30/01/2007 17:21:55 info Media ID: INFOME-R20-00
30/01/2007 17:21:55 info DMA Enabled
30/01/2007 17:21:55 info Scanned files #7, folder #2 - total size 2054789120 b. (1.91 Gb.)
30/01/2007 17:21:55 info Inserted media type : DVD+R
30/01/2007 17:21:54 info --------------Encoding end--------------
30/01/2007 17:21:54 info Media name: "xxxxxxxxxxxxxxxxxxxxxxx"
30/01/2007 17:21:54 info Burned folder: "F:\Documents and Settings\xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx\"
30/01/2007 17:21:39 info New media inserted. Burning layer is ready to write
30/01/2007 17:21:37 info Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
30/01/2007 17:21:37 info New Drive selected : 0:0:0 - SONY DVD RW DW-G120A MYS1 [E] (Ide)
30/01/2007 17:21:37 info Total size in built folder 1959 Mb., Target size DVD5 4400 Mb., Occupation 44.54%
30/01/2007 17:21:37 info Conversion completed in 00:14:52
30/01/2007 17:21:33 info ------------Converting Menu--------------
30/01/2007 17:21:33 info Generated duration 2519.52 sec., expected 2519.56 sec.
30/01/2007 17:21:33 warning 30 frames duplicated
30/01/2007 17:20:57 info Chapter #9 start at 40:15.840
30/01/2007 17:19:11 info Chapter #8 start at 35:10.660
30/01/2007 17:17:26 info Chapter #7 start at 30:5.480
30/01/2007 17:15:45 info Chapter #6 start at 25:5.180
30/01/2007 17:14:02 info Chapter #5 start at 20:9.760
30/01/2007 17:12:20 info Chapter #4 start at 15:9.460
30/01/2007 17:10:31 info Chapter #3 start at 10:9.160
30/01/2007 17:08:42 info Chapter #2 start at 5:8.860
30/01/2007 17:06:45 info Stream #1 Sync. delay : 0.00 ms
30/01/2007 17:06:45 info Stream #0 Sync. delay : 0.00 ms
30/01/2007 17:06:45 info Output Stream#1 - Audio: ac3, 48000 Hz, stereo, 192 kb/s, no automatic gain control
30/01/2007 17:06:45 info Output Stream#0 - Video: mpeg2video, yuv420p, 720x576, q=1-31, 8308 kb/s
30/01/2007 17:06:45 info Video Stream #0 Pulldown : 23.976 -> 25.00 Fps
30/01/2007 17:06:45 info Video source original frame rate: 23.98
30/01/2007 17:06:45 info PAL 25 FPS output format set by user
30/01/2007 17:06:45 info Widescreen (16:9) set automatically
30/01/2007 17:06:45 info Video bitrate 0/8308/8308 Kbps (min/avg/max)
30/01/2007 17:06:45 info Converting "F:\Documents and Settings\xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx.avi"
30/01/2007 17:06:45 info ----------------Title #1----------------
30/01/2007 17:06:45 info Project size 4.3 Gb. (57.7 Mb. audio - 4.24 Gb. video)
30/01/2007 17:06:45 info Stream #1 - Audio: mp3, 48000 Hz, stereo, 112 kb/s
30/01/2007 17:06:45 info Stream #0 - Video: mpeg4, yuv420p, 624x352
30/01/2007 17:06:45 info 2 Stream(s) found - est. duration 00:41:59.561
30/01/2007 17:06:45 info Opening file "F:\Documents and Settings\xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx.avi"
30/01/2007 17:06:45 info [ ] Don't fix audio gaps
30/01/2007 17:06:45 info [ ] Engine Log
30/01/2007 17:06:45 info Encoder quality: 100%
30/01/2007 17:06:45 info --------------Encoding begin--------------
Sorry for the long post and thanks for reading, I have wasted so many dvds trying to do this I would really appreciate any suggestions.
Thanks!
Thanks!
