gam3r said:EDIT: 1000th post![]()
Quick, go make a thread about it in GD!! You'll get a prize if you do.gam3r said:EDIT: 1000th post![]()
Insanity said:Quick, go make a thread about it in GD!! You'll get a prize if you do.![]()
gam3r said:Lol, the prize is mass flames by all other forum members?
DaveyD said:More like -400 to -2000 posts.
Stellios said:I believe there can be problems with dual core CPUs in some games, but there is a programs that will fix it, cant remember the name though. If you ask in the CPUs section they will tell you probably.
gam3r said:do you mean lagging as in internet lagging or framerate lagging?
What motherboard are you using btw?
Sorry me?pl. said:whats your spec btw
pl. said:Asus A8R32-MVP Deluxe mobo.
but it is more down to sum games aint compatible with dual![]()
mark_t50 said:1). install the latest AMD CPU drivers
2). Install the MS hotfix (if your XP SP2) as per technet article: http://support.microsoft.com/Default.aspx?id=896256 remembering to do the registry tweaks outlined in the article.
3). Check your boot.ini has the /usepmtimer at the end of the [operating system] line that boots your system
The reason I ask is that I have an X2 4400 and initially had problems with a few games such as EQ2, Rfactor, GTR plus a few others, since I did all three things above I have had much better luck with running games without having to run em of 1 core including BF2 and TRD3.
