What am i doing wrong?
26 May 2005
Wallasey
Hi people, kinda stuck and wondered if maybe someone could stread some light on my problem.Over clocked the cpu to 3.7ghz, multi at 12.5,fsb 296, core volts at 1.42v, memory at volts 2.10v. When i run prime 95, one core fails after 5 mins.Pc works great though. Any ideas?
What is the error message you get? Didn't know it could tell you what was causing the problem, the version I run just gives an error and you then have to try find out what it is? In my case it was bad RAM as I found out after running memtest86 for 8 hours.
3.7 is quite good for that CPU. a lot of people are struggling to get past 3.2-3.4. If you area pretty much at the limit, you might get a bit more out of it by giving it plenty more volts but probably not worth it.
