what AMD 939 CPU?
28 Feb 2009
I have a socket 939 motherboard i am going to use to make file server/ web server out of. It will be going inside a 1U case.
What should i go for:
- AMD Opteron 146 2.0 Ghz
- AMD 64 3700+
Or is there not much difference?
From what I've read about them (& the high regard for them too) I'd use the opteron. (& this is from a former 3700+ owner - AFAIK the stock speed was 2.2ghz)
Unless you can get them very cheap, I would seriously consider forgetting it and going for a more recent chipset. 939 CPUs and DDR are stupidly expensive for what you get.
An opty 146 wills et you back approx £20, RAM is quite expensiv if you're wanting good stuff.
The 146 I had did me a good few years before needing upgraded, very nice workhorse cpu.
