I want to create a computer component selector (which basically allows basic users to select components such as GFX card etc...and get the right motherboard to go with it) which will be hosted in a webpage, the selector will start off with AMD or Intel, then cut out the components that won't work with their choice, right untill they have a full PC. (A bit like Crucials memory selector but for a whole computer)
I want the interface to be graphical an not just dropdowns showing lists of data. Like a tree flowing down starting at CPU
What language and tools should i be looking at for something like this?
I also want to create a questionnaire which will determine what type of PC they are looking for, for example a HTPC and if so do not show full sized cases and MB's, can i link all three together? Component selector, questionnaire and the one database (which will hold all the data on a certain component)?
I've been told VB.net would be a good way to create the component selector though i've never used it, i have done VB and was ok with that though.
Thanks for your time.
