What are the pro's & con's of 'low-voltage' RAM?
2 Mar 2009
Nottingham
I have seen that various companies now offer 'low-voltage' RAM. What are the basic pro's and con's of this?
For instance if I buy an Asus AM3 motherboard and a Phenom II X4 CPU, and had the choice of either standard OR low-voltage RAM... which should I choose?
Cheers :)
Lower power consumption...but these modules also tend to be some of the best for overclocking as well.
Since newer CPUs have on-chip memory controllers the need for extra VDIMM is far less. The newer Intel cores are limited to 1.65v which is a long way down from the original 1.9v required for C2D.
AMDs Phenoms however, appear to get on well with lower voltages RAM and are ideal if you're building a power efficient system but having higher rated modules isn't a problem (1.5 or 1.65).
AMDs Phenoms however, appear to get on well with lower voltages RAM and are ideal if you're building a power efficient system but having higher rated modules isn't a problem (1.5 or 1.65). Just be carefull of older 1.9v DDR3.
Why do you say that?
I'm running ram specced at 1.8v no problem in my AMD rig.
I wonder how much wattage would be saved in comparison to using 1.35v ram as opposed to 1.8v ram. I will test this, watch this forum section within the next few weeks. ;)
I'm not entirely sure how RAM works power-wise, but if the clocks and timings were the same then the current drawn should be the same surely?
So assuming your memory used 20W at 1.8V under a 11A draw...then at 1.35V they would draw 15W...
Not really sure I was crap at Physics, but if your calculations correct I would save about £1.60 a year if my PC was on around 8-10 hours a day.
I'll still get some of this low voltage ram, it will really bug me now anyway.
ok because I am putting together my Phenom 2 build tonight and am using my 1.9V OCZ 4gb 1800MHz kit. Hopefully they play nice...
been doing some reading over at XS and it seems the AMD IMC is a lot more picky compared to Intel.
Technically C2D doesnt require 1.9 V, Most C2D's are paired with DDR2 and the official spec voltage for DDR2 is 1.8V, The official spec voltage for DDR3 is 1.575V(max).
Thing is when overclocking a lot of memory makers spec overvolted parts, so 1.8V DDR2 often ended up 2.1V etc.
Its not really that the i7's are voltage limited to 1.65V either, more a fact that pushing more than 1.65v into the i7's memory controller will fry it pretty fast as its on the die, and made with the same 45nm process as the rest of the CPU. So the ram guys have got less voltage headroom to get good overclocks from stock parts, and have had to resort to using higher than jedec spec parts to get higher clock speeds and tigher timings.
The advantages of the low voltage ram are, A) uses less voltage and power to achieve the same timings, B) slightly less temperature due to A. C) Compatible with i7 processors without risking damage to the cpu should you upgrade in the future.
Standard "Low voltage" memory should work just fine in AMD rigs, but overvolted ram is bad for i7's. Thats about it really. The AMD memory controller is more robust than the i7 one.. its design is more tolerant of voltage than i7.
Interesting, I guess it depends on your point of view. slap "high voltage" ram into the i7's and as you only have 1.65V max to play with you wont get very tight timings or high clocks out of the ram. So based on that you could say the i7 is picky too :)
