Manufacturer : GIGABYTEProduct : S775 Intel P45 ATX A L 6SATA
Manufacturer : INTELProduct : Core 2 Duo E8400 3.00GHz 6M Ca
Manufacturer : OCZTECHProduct : 2x2GB 240DIMM PC2-6400 Gold
ATi 4850 gpu.
I have already built this identical machine for my self with no problems
A failed CPU will usually produce an error beep sequence. Provided you have a mini speaker attached to the mainboard header or the board has an onboard piezo sounder.
Near instant shut off is not usually the CPU.
Make sure the board is installed correctly. If a standoff is in the wrong place it will short and the PSU will shut down after a second or so.
Make sure you have the correct 4pin ATX connector and didn't confuse it with any other.
Make sure you have a fan with a pulse wire plugged into the CPU Fan header
Make sure the graphics card is seated. Only the very top edge of the gold finger connecter should be visible (if at all) and is should be even all the way along the slot. Some cheap cases tend to lift the back edge of the card. This shouldn't cause a non boot.
Try the basics. One stick Ram, GPU, CPU (with HSF) and nothing else! No other cables for HDD, FDD, etc etc.
Make sure the motherboard header connections are correctly connected.
I accidentally connected an IDE HDD with an FDD cable... That wouldn't switch on so check everything, then check again.
AD
