- 15 Jun 2009
A good example of what I'm on about is on this block -
http://www.overclockers.co.uk/showproduct.php?prodid=WC-196-XS
The little block on the top that extends the intlet and outlet over the top so you can fit tubes on either side. Looking to buy a 7850 block but the inlet and outlet are on the bottom, In a Bitfenix prodigy that means the tubing will be hitting the window.
Can you buy these separately?
Hopefully this makes sense outside of my mind
