What are these crimp connectors called?
11 Aug 2006
Thread title, see image.
They are intended for car wiring looms.
Having difficulty finding these type of connectors online so wondering whether it would be better to salvage some old wiring loom from a scrap car instead.
Shouldn't they be inside some sort of plastic housing?
Yes they usually are in some sort of plastic block of some sort. I'm trying to find the correct connectors to add additional wiring to electric mirror connections on a Focus ST for electric folding mirrors.
I've used a few of my own ones before, looking at the pic I'm not sure what size wire they are but I'd hazard a guess that the reds might work
http://www.carbuildersolutions.com/uk/pre-insulated-red-female-bullet-pack-of-50
http://www.carbuildersolutions.com/uk/pre-insulated-red-male-bullet-pack-of-50
Building my own car I've just used these from the same company and done all my own wiring, its dead easy with a set of crimp strippers and crimp tools. Obs you could prob just get away with a pair of pliers if you were desperate but id recommend a crimp tool.
