what are these picture frames called
13 Jan 2006
Wigan
im after 5 picture frames to frame some posters, the type i want are were its just a glass pane with a board back and just has tiny metal clips on each side holding together so theres not actually a frame.
anyone know were i can get them? after some 24"x19".
thx they are a lot cheaper than what i found, place i found wanted £22 each but they were custom made.
19.75" x 23.5" on that site is close enough i think.
I'd check Wilkinsons... Fair enough it has been a while but I remember I used to put posters in them when I was a little younger and seem to remember them being much cheaper than those. Either that, or I'm ageing!!
If you're hanging them over anyplace that people sit or sleep make sure you get acrylic ones rather than glass.
before i go ahead and buy some of these, does anyone have any other means of framing them? i dont just want to pin them to the wall.
