what are these rgb fans called
29 Sep 2011
melee island
Hello, I'm trying to get some rgb fans that are rgb 4 pin header, but what are they called, I don't want argb fans that are 3 pin header connector, wasted enough money on those already
tnx
I just can't find any rgb 12v 4 pin connector fans on ocuk, at all, can anybody?
I found a filter category for 12V - it might not cover all the options but there are 2 results:
now that's what I'm talking about, thanks so much, I really appreciate you finding that
now I just need to find two 120 rgb fans that work with mystic light
That is a 3 pin ARGB fan, not a 4 pin, all RGB fans are 5v 3 pin, I don't mean a 4 pinPWM fan I mean a 12v 4 pin connector rgb fan, not RGB, big difference!
No it isn't - read the description it's specifically a 4 pin analogue non addressable one and even says 12v RGB in the specs
I know because I checked and arctic list a separate ARGB version
My basket at OcUK:
Read the specs, it's 12V.
how does that not blow the 3 pin fan?
Form factor meaning shape of plug. He's if you plug it into a 12V supply it might damage the 5V LEDs. Yes there's a big problem with standardising the connectors for RGB and it hasn't been solved yet.
My basket at OcUK:
You're right, I'm wrong, you win the internet, and I will hang my head in shame for the rest of the day
