What are these temps for?
27 Oct 2004
Stoke on Trent
i was just running super_pi with speedfan running to see the temps of the cpu underload and i just wondered what are the temps that are highlighted in the picture from (e.g chipset etc)
and is temp2 the cpu?
well which one goes up the most when u load the cpu? i reckon 1 of those temps is not real... 3c?
u'r spec would help a lot.
A64 venice 3000+ @ 2.7Ghz
1gb twin mos ram
Gigabyte nforce 3 K8NSC-939 mobo
geforce fx 5600
temp2 rises the most so that must be the cpu, still dont know about the others
well temp 1 on mine is the case temp, 2 is cpu. Speedfan reports 2 other make believe temps which i just removed from the list. If those temps never change then just ignore them ;)
Use Everest, then run speedfan at the same time, everest will tell you which is which then you can work it out.
Temp 1 - General motherboard temp (could well be the actual temp of the monitoring chip).
Temp 2 - CPU
Temp - N/A (disable it)
Temp 3 - PWM (power section of the motherboard)
