Hi everyone.
I've installed AMD OverDrive(AOD) to OC my machine, since the BIOS only allows CPU voltage up to 1.3v for some reason.
It's the machine in my sig, for info. Asus M3A78 Pro, with one of those mini-cpu cooler type NB heatsinks.
Within AOD, there are a few voltages that i'm not familiar with. Could you please help me decipher them?
cpu VID for instance. Seen people say that its the base voltage that the cpu needs to run. Why can i alter it then? Any ideas what this really is? my vCore is at roughly 1.48v
NB VID. Northbridge VID? same again for previous question. NB core is at about 1.2v i think.
mem VDDQ. Read that this is the voltage to the output buffers. defaults to 1.8v. What should this be at? I have 4x1GB GeIL 6400C4 Ultra (1.9-2.3VDIMM rated. Runs amazingly well.) VDIMM is currently set to 2.1v
mem VTT. Not a clue about this one. It's about 0.9v default.
Currently, my temps are all awesome. NB gets to about 48 under half an hour of an AOD stress test. Fails after about 15 minutes of Prime95 due to bad readings... I want to try and fix this.
Cheers guys. Hope to hear from some of you soon.
