What are your 12900ks SP and Cooler Asus scores ?
5 Jul 2007
Probably just your average 12900ks....
SP 88
P-Core SP 97
E-Core SP 72
Cooler Points 164
Noctua NH-D15s Heatsink and Thermal Grizzly Kryonaut Extreme paste....
Cooler points down from 171 yet possibly due to hitting 100c while installing cyberpunk. Average cpu temp while gaming at 4k 70-80c
What are your 12900ks points on asus ?
I only have the normal 12900K
SP86
P cores 95
E cores 70
Not sure why you would go with the KS with a ddr4 board and the air cooler. seems like a odd combination. Have you tried undervolting it at all? i think a negative voltage offset would help your clock speeds.
SP86
P cores 95
E cores 70
DDR5 has little advantage to it for now as reported by many sites. I'm shying away from water cooling for the time being yet definitely looking into it. My D15s works fine in general and is the largest and best air cooler that'll fit my case. I've heard of undervolting yet prefer not to fiddle with stock settings...
I'm not sure what info you want as you said you are not prepared to change stock settings. Your temps seem fine and your CPU would be a decent overclocker and your cooler is a decent cooler but if you are not going to "fiddle with stock settings" then it's a moot point. If everything works then just use it and enjoy it, there seems no real point to this thread.
Can I not ask a simple question on this forum ?
