What are your temperatures / case / cooling ?
27 Oct 2007
As is illustrated in the title, what are you running at idle / load.
What case / cooling / spec ?
I have awesome cooling when you consider i have an £11 Z-Alien case.
Case: Z-Alien Black
Cooling: 2 x 90mm Side Exhaust Fans, Zalman CNPS500 ( or similar ) AM2 Cpu Cooler, 8800GT Fan @ 60%
Temps;
Idle
24 degrees @ CPU ( AM2 X2 5000+ 2.6Ghz )
27 degrees @ system
39 degrees @ 8800GT OC 512MB
Load
33 degrees @ CPU ( AM2 X2 5000+ 2.6Ghz )
35 degrees @ system
50 degrees @ 8800GT OC 512MB
Measured via nVida control panel
Antec 900 2x 120mm intake, 1x 120mm exhaust, 1x 120mm side intake, 1x 200mm top exhaust all on high.
E6600 @ 3.6ghz 1.424V + Arctic Cooling Freezer 7 Pro
Idle: 22-24C
Load: 58-60C
System: 25C
8800GT 1.1V 740/1782/1000 44C idle, 60C load stock cooler.
Intakes - 4X 120mm and 2X 92mm
Exhaust - 2X 120mm and 2X 92mm
Not really sure what idle is its very rare its not busy. But right now its doing folding and temps are
Core is 28C
Case 25C
Idle
Core 0/1= 33deg
VGA = 52deg
Load
Core 0/1 = 59deg
VGA = 61deg
Case = Antec 900 with the extra side fan making it 4 x 120mm and 1 x 200mm.
Cpu cooler = Noctua.
System in sig, in a coolermaster ATC-201-SXK:
On the Modded Vapochill XEII -7ºc idle, 5ºc load.
On the stock cooler (ie when I cba with the mess or noise of the vapo) - 37ºc idle, 50ºc load.
Idle
CPU: 29 - 33
SYS: 27 - 32 (PWM: 38 - 41)
GPU: 49 - 51
Load
CPU: 38 - 45
SYS: 30 - 35 (PWM: No idea)
GPU: 62 - 68
PC room is quite hot generally, probably never under 25c.
Sys: e6400, P180b, 8800gts 512. Everything is at stock, very low RPM/silent mode (cpu about 600 RPM, no idea what GTS is running at but I can't hear it at all). 3x 120mm case fans running at 5v.
Temperatures are useless without listing ambient. ;)
Case: Custom Lian Li PC60:
Cooling: Custom waterchiller and single stage phase
CPU idle: Condensor @ -60c stock, -55c with 1.8v
CPU Quad core 1.8v 4.8Ghz ish depending on bench @ -35c load
Chipset: as low as -2c, 8c load.
Southbridge: 28c
System: 30c
Volt modded 8800GTX: -2c, 8c load
Ambient: c18c
Bad photo
opteron 175 @ 2.2 GHz
Sugo SG01e Small form factor (all 3 fans in use) using passively cooled nt06 (tagan easycon 480W with 120mm fan)
CPU
idle - 26-34C depending on room temp (currently 27C)
load - 55C tops
System
27C - never changes :)
Hard Drives - 25C
