What are your temps in this heatwave
17 Dec 2004
Room temp 28c.. my gpu gpu/hotspot is in the low 40s normally
Idel temps
I have higher idle temps than normal (my GPU usually sits around 30c and my CPU at 40c since the AIO on it is an exhaust).
When it's hot then at 10c to both.
Gaming temps actually are the same as pre-heat, so all in all I will call it a win
Both GP and CPU went up by 13C.
The new Bios firmware I flashed reset everything fans\overclock\ram ect. :mad:
Now I have gone through the bios settings again...all is ok :D
When only between 24C and 27/28C, I left the system on little/no noise generation and Idle temps remained +7-8C above ambient. (25% to 35% Fan Speed)
When it hit 29-30C and more, opened the windows and doors to City noise (Traffic, etc), and can lower the Idle temps a bit more through more aggressive fan speeds. +8-9C above ambient. +30-45% fan speeds though (up to 75% Fan Speed), although that's also for when seriously using the CPU and GPU as well. Which can send internal case temps to 55C or more if not exhausted quickly enough (hence the increased fan speeds).
Idle 35-40c, gaming 50-55c and that's with case panels on plus fans on silent.
My 4770k prior to this used to hit 75c often when gaming. :D
My system was around 40C, CPU was around 46c while doing light work load.
when I games on fallen order CPU hit 76c and system was nearly 45c. Room was easily high 30c, it was uncomfortable,
Put it in perspective, my system was running at 30c system, 40c idle, 60c full load just prior to the heat. Room temp was probably around 25c.
Glanced at temp graph and maybe a couple degrees warmer at most, but fans are spinning a little faster than normal. But I'm on the coast so don't get hit by hot weather inlanders do. :D
3950X is currently running at up to 70c* under full load with gaming load being more like 55-60ish - note custom water with 360mm RAD and Corsair ML120 fans
GPU (Gigabyte RTX 3070 Gaming OC 3x) is sitting happy at 64c.
*Reported by Motherboard readout (MSI X570 Unify), HWInfo and sense checked against Ryzen Master. All within margin of error of each other.
My temps are in the 44 on some cores and when gaming I’m getting lock ups seen cores hitting 97 playing doom 2016 and then a lockup might just leave the overclock off till the weather changes.
