What binned Hardware gets you..
4 Dec 2021
UK
Hi All,
So in case you were wondering what binned hardware gets you in terms of performance I decided to do a short video. I believe with all this binned hardware I'm only able to get 10-15fps max above stock.
10900K @ 5.3GHZ Sp103
Ram OC 4100MHZ CL16
Sapphire 6900xt Toxic Extreme Edition.
Could run other games if I get requests.
I'm currently running the same thing in clocks :D I notice a difference in Skyrim with texture mods and an ENB where every frame rate counts!
I'd like to know what your system does compares to mine in terms of memory clocks ( 3200mhz vs 4100mhz ), what's your cpu volts man? :)
hmm i think 3600mhz and 4100mhz are similar not sure with 3200mhz.
I'm running 1.28V LLC 4. 5.3GHZ all core, 5.4GHZ 7 core, 5.5GHZ 6 core. Cache 50.
