What BIOS to flash on a MSI R9 280X LE
18 Oct 2002
Hemel
I've just installed two of these into my machine and they seem to be happy.
Under heavy load though (cgminer mostly) one card gets quite a bit hotter than the other (85-90c compared to 80-85c on the other). That's hotter than I'm comfortable with.
I've seen other people mention flashing the card may reduce temps somewhat, but I have no idea what BIOS to use. I'm assuming as the LE is the same card as an OC I can just use this one http://www.techpowerup.com/vgabios/146769/msi-r9280x-3072-131009.html
Currently GPU-Z says that both cards are running 015.040.000.001.003435. As this other BIOS is 015.040.000.000.003435 surely that's a downgrade?
I'm worried about frying something either through heat or a bad bios flash!
