1 Nov 2013 at 17:39 #1 Tattooed Tattooed Associate Joined 14 Aug 2003 Posts 1,984 Location cyberspace Hi, What cables do I need to connect an pod touch to a Sony STRDN1030.CEK AV Receiver? Thanks
1 Nov 2013 at 17:46 #2 Deleted member 77746 Deleted member 77746 Permabanned Joined 9 Aug 2008 Posts 35,711 A simple "3.5mm to rca" will do the trick. https://www.google.co.uk/search?q=S...4G4BQ&ved=0CAkQ_AUoAQ#q=3.5mm+to+rca&tbm=isch
1 Nov 2013 at 17:52 #3 andy_mk3 andy_mk3 Soldato Joined 5 Oct 2009 Posts 14,364 Location Spalding, Lincs Yeah as above really, that's about your only option unless you decide to airplay.
1 Nov 2013 at 19:28 #4 Tattooed Tattooed Associate OP Joined 14 Aug 2003 Posts 1,984 Location cyberspace Hi, Thanks for the replies. Where do you get airplay from?
1 Nov 2013 at 19:37 #5 andy_mk3 andy_mk3 Soldato Joined 5 Oct 2009 Posts 14,364 Location Spalding, Lincs You can play audio straight to the amp over wifi, or through iTunes
