Hi
I have 2 laptops..
a) Fujistu s6120
b) fujistu amilo 1705li
trouble is the s6120 has a cracked screen which will cost me £160 to purchase I would put it in myself and mobo and all other things are working fine..
meanwhile the amilo I believe has a dead mobo which I can get for around £130 but am not to confident its just the mobo or putting it all back together..
Is there any way I can rebuild the s6120 inside the casing of the amilo? bearing in mind the s6120 is a 15.4inch and the amilo is a 17"...
if not, what would you recommend? pls advice..
cheers
I have 2 laptops..
a) Fujistu s6120
cheers
