What can i get for £280 or less
25 Nov 2007
Crewe
Still got my 6870 from 2010, I am looking for something under £280 to go with my 2500K @ 4.5. I don't really care if it's AMD or Nvidia.
I was looking at the Gigabyte GeForce GTX 770 WindForce 3x for £275 and the Asus Radeon R9 280X DirectCUII for £281.
Are these ok or can i get something else cheaper for the same performance?
I would go for the R9 280X as its that bit more future proof with 3GB, where as the 770 has only 2GB especially for gaming, as they both have similar performance.
I don't think the sapphire flashes to 290x, the free games should easily net you around £35-40 on the mm :)
If buying right now then a 280x or 290 would be the cards to look out for. Its a bad time too buy though supply simply is not keeping up with demand so prices are high
