What can I realistically expect as a max OC?
13 May 2007
London
As per title for an e8200 cooled by a scythe ninja in a p5k-e Wifi coupled with 4gb OCZ 6400 plat xtc. (case: antec 300 with 4 120 sharkoon eagles at 1000rpm and 1 antec tri-cool 140 on low.)
I know obviously it depends on the chip itself, but just a ballpark figure so I know where to start come monday when it arrives.
Thanks for your help!
That's gonna be a sweet machine SS-89 :)
I hope you can take some photos, I want to see a few builds in that new Antec case.
Also that ASUS mobo is really good, used it for 6 months approx and never had a problem with it! :cool:
Will do m8 although my cable management skills are non-existent I will be trying my best with this build :p I may push for 3.8 though :D Anyone know the fsb wall of the p5k-e and what's the max voltage to put through these 45nm?
As Promised! No bread I'm afraid :D, First actual concerted attempt at cable management...verdict= I suck :p
Very very quiet pc atm, 4 sharkoons are excellent :)
I've got my E8200 running at 444 x 8 (3.55GHz) @ 1.29v in BIOS, 1.27v in Windows and I didn't have to play with any of the other voltages. I reckon 3.8GHz should be obtainable but I've not tried as yet.
Both cores idling at 35 degrees which I assume is good enough for now? AS5 obviously has a cure in period.
