Hi all its been a good few years since I got my pc and I’m looking to upgrade probably around Jan some time depending on availability and how the radeon cards compare.
This is my current build:
Asus Z170-E Intel Z170 (Socket 1151) DDR4 ATX Motherboard
Intel Core i5-6600K 3.9GHz (Skylake) Socket LGA1151 Processor - Retail
Kingston Fury Black 16GB (2x8GB) DDR4 PC4-19200C15 2400MHz Dual Channel Kit - Black (HX424C15FBK2/16
Samsung 250GB 850 EVO SSD 2.5" SATA 6Gbps 32 Layer 3D V-NAND Solid State Drive (MZ-75E250B/EU)
Seagate 1TB 7200RPM SATA 6Gb/s 64MB Cache HDD - OEM (ST1000DM003)
be quiet! Silent Base 600 Midi Tower Case - Orange
be quiet! Dark Rock TF CPU Cooler - 135/135mm
Corsair Builder Series CX 600w Modular '80 Plus Bronze' Power Supply (CP-9020060-UK)
MSI GeForce GTX 980Ti Gaming 6144MB GDDR5 PCI-Express Graphics Card (GTX 980 Ti Gaming 6G)
So I know I will have to upgrade mobo and cpu, looking at the 5600X, I’ll either be going for the 3080 or radeon equiv depending on pricing.
I’ve been reading up and I want x4 8 gig 3200 cl14 ram to pair with the amd cpu as I guess that is the fastest option.
Would i be able to reuse the psu or is a new gfx card going to draw too much juice, also I’m guessing i wouldnt see much of an increase in gaming with a nvme hd compared to what I already have?
Gigabyte is the mobo brand I’d rather go with as I’ve never had any issues with them(the spec there is wrong i actually have a gigabyte board) wifi would be handy as atm I’m using power line adaptors which I’ve never had issues with I might add if it adds too much to the price then its not a must.
Thanks in advance and sorry for the jumbled wall of text
