What can I upgrade on my pc ?
17 Feb 2013
Hi,
The specs for my PC are
Operating System
Windows 10 Home 64-bit
CPU
Intel Core i5 2500K @ 3.30GHz
Sandy Bridge 32nm Technology
RAM
8.00GB Single-Channel DDR3 @ 665MHz (9-9-9-24)
Motherboard
Gigabyte Technology Co. Ltd. Z68X-UD5-B3 (Socket 1155)
Graphics
PL2773HD (1920x1080@60Hz)
1535MB NVIDIA GeForce GTX 580 (CardExpert Technology)
Storage
59GB M4-CT064M4SSD2 ATA Device (SATA (SSD))
931GB SAMSUNG HD103SJ ATA Device (SATA )
1863GB Seagate Expansion Desk SCSI Disk Device (USB (SATA) )
Optical Drives
HL-DT-ST BD-RE BH10LS38 ATA Device
Audio
Realtek High Definition Audio
What can I upgrade on this ?
Well quite frankly, you could upgrade everything. Apart from the OS, everything can be updated. The question is what should you upgrade and that depends on what you want to do with your machine. :) Letting us know that and how much you would be willing to spend to achieve that would be helpful.
Thanks for the reply, I use the computer for Gaming and also photography so its mainly that area that I would be looking at. Budget wise I am not sure something to make it run at speed etc.
depending on your power supply which id imagine to be good to run a 580 unless a cheap brand then a gpu upgrade would be your first and best option if on a strict budget, the 2500k might be getting on a bit now, but a 500 series nvidia is only supported via legacy drivers now pretty much, so your going to struggle if you game.
GPU first, then CPU (i7-2600/2600K), then more RAM (but only if you see it maxing out the present 8GB). Other than that maybe a bigger SSD for OS and programs. I wonder if part of the "run at speed" request has to do with some programs installed on mech drive instead of SSD? Can you elaborate on what doesn't feel fast enough? Is it just when gaming, or general snappiness not up to par or other?
