What card for my Sugo SG03?
5 Apr 2008
Deepest, Darkest, Essex.
I do know that pretty much anything will fit, as I have a GTX280 at the moment and that will go in, but I want something a bit smaller and cooler, that's all.
Should I be looking at single slot? And are there any low profile cards worth considering?
I don't want to dip dramatically below the 280 in terms of performance, as I play my games on a 26" screen, but I'm confused by the sheer number of different cards available.
I'd prefer to stay with Nvidia, but that's only because I have only ever used their cards, so if there is an overwhelming push towards a particular ATI then I'll consider it.
Considered a 260? my Gainward Gold Sample runs really cool and can be overclocked to high heaven.
No, I hadn't actually. :o
I kinda thought they were the same architecture as the 280. Is the Gold a particular example, and do you know if they are the same physical size?
