What card for use with steam link?
What's your budget?
4GB Sapphire Nitro at £199.99 will be pretty hard to beat.
Basically, if your budget stretches to £200-250 either a GTX 1060 or an RX 480.
If you can't stretch to that aim to get a 2nd hand 970 for ~£150.
I presume you are using nvidia encoding?
if you have a decent cpu try running the encoding on the cpu - i was using my i5 4670k to do it no problems (without the igpu) as amd encoding was really bad on my old 280x
Giz
