What Card
11 Nov 2013
I am running aP6T Deluxe V2 motherboard with a i7 CPU 16GB Ram and have a AMD Radeon HD5700 series card, PSU is max 600watts all in a titan onyx case, I want to up date my graphics card and have been advised that a GTX760 Phantom will give me a good upgrade for my budget of £250 would you guys agree.
I want to run Bf4 and other games on this.
if it is for BF4 i would go with AMD on that budget, especially as Mantle could give you a great boost when it arrives.
As above the 7970 or 280x would be my choice.
Cheers for the response but a 3 fan card will not fit in the case.
the GTX760 Phantom is a 2 fan card and at 10 inches just fits in the space.
Do you guys think it is better than the one I have after that info
Yes I agree that these are faster but at 308mm they are to long for the case so it looks like it will have to be the GTX760.
Thanks for your help though much appreciated
