What case can fit 3 triple rads ?
with a little modding a silverstone TJ07
i takes 2 in the bottom and you would need to mod the roof to accept the other as at stock it only supports a dual rad.
Actually the TJ-07 can fit a quad rad and a dual rad no problem at all in the base (see HERE) Also the corsair 800D can house a triple no problem at all!
TJ07 cant fit two triples in the bottom, you would have no room for the power supply.
on the flipside of this, the only other cases i can suggest that would accomodate those radiators would be a lian li 343b
The standard U2-UFO cant fit three triple rads. It can fit 1x360, 1x240 and maybe some singles if thats your bag.
The MM Ascension can fit four triple rads. The 343b can fit three at a push with modification.
Other than that your pretty much limited by case choice I'm afraid.
Go for broke and fit four?
...but then that would be crazy right? :P
